First of all I would like to say that RaceChrono is really wonderful software and to have better resolution for analysing cornering speeds, I bought recommended Qstarz 5Hz edition GPS receiver.
I would like to apologize because my problem is not RaceChrono related (receiver works great with RaceChrono) but because there are many users here that have Nokias and these receivers i thought it should be a proper place to get help.
The problem is that programs in which you can select receiver work (RaceChrono, Garmin XT) but the programs that don't have receiver selection report GPS not available. These programs are Nokia GPS Data and Nokia Sports Tracker.
Thank you for your help!
All of the Nokia software use an internal API that automatically use the paired devices list for selecting the default GPS device. So the old one needs to be unpaired, so another one can be used.
RaceChrono also uses this same API when GPS type is set to "Internal GPS", hence a Bluetooth GPS can also be used through that setting... :-)
Anyhow, I found i don't use the iBlue anymore so I delete it as well.
Could you check if the nokia sport tracker new version will log with 5Hz receiver. I am just curious thats all.
