I've been trying to get Trackvision to recognise the Pandora csv export file with no success. I'm using the latest version Pandora, I've tried all the different Data Loggers in Trackvisions preferences but I never get a track map or any other data to load.
Please if someone can give me the setting to use it would be most appreciated.
P.S. I'm using a Qstars 818 as the GPS antenna.
I'm also testing the demo only, so I'm no expert. I seem to have other problems, can't get the dashboard on the video at all. The generated video is just plain video. Maybe some codec problem.
With the dashboard/trackmap problem, I think I had the same thing. Make sure you install the pandora.properties file in the TV loggers folder ( which is invisible ). Then you need to select it in Trackvision's preferences.
Hope this helps. The TV forum is a bit hit or miss on some info.
I probably have different problem, as I'm using RaceChrono specific properties file. Also it seems to work on my friend Roberto's computer.
