Hi, I have been reading about how using accelerometers, gyros etc. all have their issues with calculating lean angle while moving due to all the forces at play. Apparently it is possible to calculate the lean angle using GPS data. Something about using GPS position and the curve from reading coordinates etc. Not sure exactly, but I am doing some research. If possible, could this be added to RaceChrono as a value to capture?
I have tried using sensors and kalman filters, but doesn't work to well when your moving, but works fine when stationary. Also the data is very noisy even with a kalman filter.
Thanks.
If the op wants to send me his ideas I can try to process my data and see what I get.
Dave
