I just bought the Pro version and have linked several videos to sessions from my most recent track day. All works fine until I try to export them. The export fails and the queue says "failed, process died". Same problem for either internal or external memory. Videos are .mov files created with Mobius Action Cam. Tablet is Samsung Galaxy Tab Pro with Android 4.4.2. Any suggestions?
You could try to uncheck the "hardware acceleration" checkbox at export config. Then the video export will use FFmpeg software codecs instead of hardware codec.
What you can do is try to use some software to transcode the video before uploading it to the phone. The Video stream can be intact, but Audio needs to be AMR codec. This way you will get both video and audio on the phone.
You might also try to see if the camera has any audio encoding settings.
