Import exported data from Harrys Laptimer Iphone version in to Racechrono
is it possible t Import exported data from Harrys Laptimer Iphone version in to Racechrono? I got a csv file that i friend exported for me. Well i need to find out vmin and vmax at all sectors of Nordschleife and its not a must to do it with racechrono but i like it.
    edited September 2015
    Currently there's no import option, but if you can export NMEA from Harry's you can import that in RaceChrono. The way to do it is bit tricky, basically you create /RaceChrono/input/ folder and copy the NMEA file there, and then configure "NMEA file" as device, and select the file. Then when you start a session, it will play it back 4x speed, and you end up with the session. This is a debug feature but maybe useful for other things too :)
