i've got a synchronisation problem with a selfmade datalogger that uses the $RC2 sentence format to communicate with RaceChrono 4.3.9 on my Android phone (Samsung S4 mini):
$RC2,[time],[count],[xacc],[yacc],[zacc],[rpm/d1],[d2],[a1],[a2],[a3],[a4],[a5],[a6],[a7],[a8]*checksum
I send the $RC2 sentence with 50Hz via bluetooth and use the count field. I use the Qstarz bt-q818xt GPS module with the 5 Hz mode.
The figure shows the normalized velocity measured by the GPS module an my datalogger.
https://www.dropbox.com/s/riohz0puealnnws/syncProblem.png?dl=0The time delay in the beginning of the measurement is much smaller then in the end. It seems the GPS time stamps in the exportet vbo file is correct (the lap times are correct).
Can anyone pleaae help me?
Best regards, Jakob
I had similar issues in my previous setup and at the end it seemed to be a problem with BT-q818xt. The timestamps and positions sent from GPS seemed to be precise but sent with some delay and the speed of sending them from (probably) some buffer within GPS was not constant resulting in varying delay between GPS and my own data. I haven't managed to overcome this. Instead I changed the general idea of the device and stopped using external gps.
There were threads discussing similar issues:
http://www.racechrono.com/vanilla/discussion/942/whats-the-best-settings-for-use-with-the-qstarz-818xt
http://www.racechrono.com/vanilla/discussion/951/racechrono-with-qstarz-q818xt-obd2-poor-synchronization-lag
Notice it's important to increase the counter even if you have to drop a sentence. Because that's a sure way to have your logger data advanced, if you do updates like this:
0.1s counter = 1
0.2s counter = 2
0.3s counter = 3
0.8s counter = 4
0.9s counter = 5
1.0s counter = 6
What you need to do is:
0.1s counter = 1
0.2s counter = 2
0.3s counter = 3
0.8s counter = 8
0.9s counter = 9
1.0s counter = 10
If this is the case, should of course fix my code to allow this...
Here is an example of the dataloggers output saved on a sd-card but it is the same sentence send to RaceChrono with bluetooth. The relative timestamps are at the last field in milliseconds.
https://www.dropbox.com/s/wucf7lncgmfijc7/DATALOG_part.TXT?dl=0
Oh damn, now i see every 1000ms i have a big delay between two counts (aroaund 77ms) because i'm closing the file on the sd-card in that moment. That should cause trouble with your counter-sync-method.
I will fix that and report again!
