config:
htc one m9 (stock, no root or others hack android 6.0)
if mp4 video files (only created by gopro 3, if files created by phone all is ok) for session have size more than 1 gb, racechrono pro don't link this files to session. if files not linked to session, impossible export session for viewing with overlay OBD (GPS) telemetry.
if files less than 1gb, all is ok...
How to solve a problem?
After copying files from GoPro on a smartphone, you can not append and view videos.
The file may have been damaged as a result of copying.
I will try to reproduce the problem and write the details a little later.
- Make sure you copy over MP4 files (from camera), NOT the WMV files from GoPro studio
- Make sure you record GoPro video only up-to resolution supported by your phone. When phone camera can do only 720p, then high probability is that it will not play back, or at least will not export 1080p video
- Try playback on the phone video player first, to make sure the video works and can be played back with the device
Yep, i copy only MP4 files.
primary cam: 2160p@30fps, 1080p@60fps, 720p@120fps
secondary cam: 1080p@30fps
gopro recoded video in1080p
After copy files to the phone, i tryed playback. Video not played.
