Just upgraded to RC Pro. Liking it. Went testing today. Got some video to link nicely with the first session.
When I stopped the recording of the second session I must have done something wrong. Maybe pressed "back" on my phone before stopping the gopro. Not entirely sure. Anyway the upshot is that in the RC sessions screen I says I have 2.4GB of data in a run but no time and no distance. This compares nicely with the 2.5GB I have from the first session of about the same length. Both sessions have been allocated to the correct track.
Anyone able to guide me to how I met salvage the data. An MSc student needs the data for their dissertation, so it is mildly important
GWO
There's so many possible variables that I cannot really imagine the scenario... but you can check if there is data by going to the session folder at:
/Android/data/com.racechrono.pro/files/sessions/session_(date)_(time)/
There you have files named "channel_*". Each file grows 4-8 bytes on each update. So if you have one hour of data, with 10 Hz update rate, you should have between 4*10*3600 - 8*10*3600 bytes on each of the file. If these files are 0 bytes in length or very small, then it has failed to record for some reason.
thanks for the quick response
