hi during the installation of racechrono2avi , Norton security program blocks it. Should I turn off Norton and continue, or it will be a problem? Thank you
thank you for your quick response. Is there any other program you can suggest me like rc2avi? I have Racechrono pro with Qstar818 and Gopro+. Any help would be appreciated.
You could set it as GoPro 2. Should work. That said you can copy over the video files, and link them to your session. After that you can do the exports!
First of all, thank you for your concern. Unfortunately, when I set GoPro+ as GoPro2 all I get is "unable to connect". The same happens even if I choose GoPro 3/3+. The connection is able only as GoPro4, but I can't get any access to video, only to camera's "on" or "off".
Ok, I guess it's not compatible then. You should be able to import the video files even afterward without using the remote control feature. Here's how to sync the videos with your session: http://www.racechrono.com/news/?p=480
