Ciao, I recently made nice video using racechrono but one thing still missing is the Pip. If I have two videos how can I do to add the second one in the picture (Pip)? I already tried selecting the channel 2 for the second video but no way to add. The possible choice is between video 1 and video 2, not both. Is there a Tutorial? Where am I wrong?
Thanks a lot.
Giank
NDR. (both video are recorded with gopro 3 and 3+. Both added in the folder of movies, perfectly working)
1) You need Android 4.4 or later
2) On video list (behind the round "Videos" button), click the number icon on each video file, and set the "Video channel 1" for main video and "Video channel 2" for PIP video. The channel selection is free, but this is just for sakes of the example.
3) Tap the export button, and then "More..." button on the export form
4) Make sure "Hardware acceleration" checkbox is enabled. PIP is not supported on software codec.
5) Select "Video channel" and "PIP video channel" from the drop downs in the form.
6) Start exporting
7) Profit
/Android/data/com.racechrono.pro/files/logs/video_export_log.txt (Pro) or
/Android/data/com.racechrono.app/files/logs/video_export_log.txt (RaceChrono)
as info in addition I can say that after many tries, I cannot understand why, instead of fail immediately now start exporting and then around half job..fails.. during the weekend I will try to do a new data logging and let's see.
I don't understand the software compiling but seems to be an issue of codec?
03/Nov/2016 18:03:37 Input video format: {csd-1=java.nio.ByteArrayBuffer[position=0,limit=8,capacity=8], mime=video/avc, frame-rate=25, rotation=0, rotation-degrees=0, height=960, width=1280, max-input-size=1572864, durationUs=403080000, csd-0=java.nio.ByteArrayBuffer[position=0,limit=56,capacity=56]}
03/Nov/2016 18:03:37 Bitrate: frame height = 960
03/Nov/2016 18:03:37 Bitrate: retry = 0
03/Nov/2016 18:03:37 Bitrate: quality = 2
03/Nov/2016 18:03:37 Bitrate: quality multiplier = 1.0
03/Nov/2016 18:03:37 Bitrate: hw max = 17000000
03/Nov/2016 18:03:37 Bitrate: retry multiplier = 1.0
03/Nov/2016 18:03:37 Bitrate: guesstimated max = 40000000
03/Nov/2016 18:03:37 Bitrate: brute force bitrate = 15000000
03/Nov/2016 18:03:37 Bitrate: using bitrate = 15000000
03/Nov/2016 18:03:37 Output video format: {height=960, width=1280, bitrate=15000000, mime=video/avc, frame-rate=25, i-frame-interval=10, color-format=2130708361}
03/Nov/2016 18:03:37 Output audio format: {aac-profile=2, mime=audio/mp4a-latm, channel-count=2, max-input-size=1572864, isDMCMMExtractor=1, durationUs=403072000, csd-0=java.nio.ByteArrayBuffer[position=0,limit=5,capacity=5], sample-rate=48000}
03/Nov/2016 18:03:37 Output audio format: {aac-profile=2, bitrate=128000, mime=audio/mp4a-latm, channel-count=2, sample-rate=48000}
03/Nov/2016 18:03:37 Input video format: {csd-1=java.nio.ByteArrayBuffer[position=0,limit=8,capacity=8], mime=video/avc, frame-rate=30, rotation=0, rotation-degrees=0, height=1080, width=1920, max-input-size=1572864, durationUs=949315033, csd-0=java.nio.ByteArrayBuffer[position=0,limit=56,capacity=56]}
03/Nov/2016 18:03:38 General failure
03/Nov/2016 18:03:38 android.media.MediaCodec$CodecException: Error 0xfffffc03
at android.media.MediaCodec.native_configure(Native Method)
at android.media.MediaCodec.configure(MediaCodec.java:577)
at o.gm.(:44)
at o.gl.ˊ(:3097)
at o.gr.ˊ(:123)
at o.amo.ˊ(:255)
at o.ana.run(:90)
thanks a lot
It has codec failure when opening the PIP video, so looks like your phone hardware does not support opening two input video streams at same time ( meaning PIP does not work because of hardware limitation ). If both of the video channel export fine as standalone video then it confirms this.
Which phone is this, brand and model? I've seen this only in few phones, like certain model of Samsung S4, but not all of them as they come with different GPUs...
