Hi! Camera and iPhone are connected and the Capture-App shows the Cam-preview. Under Settings in RaceChrono i can't see an option to add a camera. I can only switch of/on the internal cam.
Hi, unfortunately you need to update your phone to iOS 10. As mentioned in feature list, the GoPro remote control is only for iOS 10 and later.
Reason for this limitation is that iOS 9 does not allow to connect to HTTP (without encryption) to arbitrary IP-addresses even if they are local network... It's a bug in a system called "App Transport Security". Although it might be argued if this system really increases security or not.
