Exporting synced video as mp4 "Failed Video Audio Codec"
hey there,
i have a problem. i use a gopro hero 4 session.
after exporting the videos from the gopro to my pc and send them then to my sd card on my cat s30.
opened it in the racechrono app, everything themes to be fine and looked good, tryed to export the overlayed mp4 video and the it says: "Error: Video/Audio Codec"
regards,
JJS
  • 12.09.2017 8:12:01 nachm. Input video format: {csd-1=java.nio.ByteArrayBuffer[position=0,limit=8,capacity=8], mime=video/avc, rotation=0, rotation-degrees=0, height=1080, width=1920, max-input-size=2073601, durationUs=720219500, csd-0=java.nio.ByteArrayBuffer[position=0,limit=60,capacity=60]}
    12.09.2017 8:12:01 nachm. Bitrate: frame height = 1080
    12.09.2017 8:12:01 nachm. Bitrate: retry = 0
    12.09.2017 8:12:01 nachm. Bitrate: quality = 2
    12.09.2017 8:12:01 nachm. Bitrate: quality multiplier = 1.0
    12.09.2017 8:12:01 nachm. Bitrate: hw max = 14000000
    12.09.2017 8:12:01 nachm. Bitrate: retry multiplier = 1.0
    12.09.2017 8:12:01 nachm. Bitrate: guesstimated max = 40000000
    12.09.2017 8:12:01 nachm. Bitrate: brute force bitrate = 15000000
    12.09.2017 8:12:01 nachm. Bitrate: using bitrate = 15000000
    12.09.2017 8:12:01 nachm. Output video format: {height=1080, width=1920, bitrate=15000000, mime=video/avc, frame-rate=30, i-frame-interval=10, color-format=2130708361}
    12.09.2017 8:12:01 nachm. OVC initialization failed
    12.09.2017 8:12:01 nachm. android.media.MediaCodec$CodecException: Error 0xfffffc0e
    at android.media.MediaCodec.native_configure(Native Method)
    at android.media.MediaCodec.configure(MediaCodec.java:580)
    at o.mV.ˊ(:49)
    at o.mS.ˊ(:185)
    at o.mQ.ˎ(:52)
    at o.mZ.ˏ(:114)
    at o.DS.ˎ(:255)
    at o.Ep.run(:96)
    12.09.2017 8:12:01 nachm. Bitrate: retry = 1
    12.09.2017 8:12:01 nachm. Bitrate: retry multiplier = 0.75
    12.09.2017 8:12:01 nachm. Bitrate: guesstimated max = 33750000
    at o.mV.ˊ(:49)
    at o.mS.ˊ(:185)
    at o.mQ.ˎ(:52)
    at o.mZ.ˏ(:114)
    at o.DS.ˎ(:255)
    at o.Ep.run(:96)
    12.09.2017 8:12:01 nachm. Bitrate: retry = 2
    12.09.2017 8:12:01 nachm. Bitrate: retry multiplier = 0.5
    12.09.2017 8:12:01 nachm. Bitrate: guesstimated max = 27500000
    at o.mV.ˊ(:49)
    at o.mS.ˊ(:185)
    at o.mQ.ˎ(:52)
    at o.mZ.ˏ(:114)
    at o.DS.ˎ(:255)
    at o.Ep.run(:96)
    12.09.2017 8:12:01 nachm. Bitrate: retry = 3
    12.09.2017 8:12:01 nachm. Bitrate: retry multiplier = 0.25
    12.09.2017 8:12:01 nachm. Bitrate: guesstimated max = 21250000
    at o.mV.ˊ(:49)
    at o.mS.ˊ(:185)
    at o.mQ.ˎ(:52)
    at o.mZ.ˏ(:114)
    at o.DS.ˎ(:255)
    at o.Ep.run(:96)
    12.09.2017 8:12:01 nachm. Bitrate: retry = 4
    12.09.2017 8:12:01 nachm. Bitrate: retry multiplier = 0.0
    12.09.2017 8:12:01 nachm. Bitrate: guesstimated max = 15000000
    at o.mV.ˊ(:49)
    at o.mS.ˊ(:185)
    at o.mQ.ˎ(:52)
    at o.mZ.ˏ(:114)
    at o.DS.ˎ(:255)
    at o.Ep.run(:96)
    Cannot create video output stream
  • works not without hardware acceleration
  • 1) How did you export the videos on your PC? Make sure you use the raw video files from the camera, since you need it to be in encoded with h.264 and AAC codecs, in .MP4 or .MOV container. A .WMV file will not work, or a file with wrong codec.
    2) As your phone is a bit low end, it might be it does not support full HD transcoding. You might try if 720p videos from your GoPro work better.
    3) Disabling hardware acceleration should make it work if the problem is with 2). If that does not work either then send me logs for that too.
  • it "worked" without hardware acceleration, but its totaly cutted. the sound is playing normal, also the timeline runs but there are only frames that stay for 20-30 seconds. the video is like a very slow gif.
  • How about other point I made?
  • i wouldnt like to record in 720p. is there a way to sync and render the files on windows platform?
    edited September 2017
    Trying it with 720p would confirm this is the problem, and not the codec as in point 1). If it is indeed a low end hardware not supporting 1080p transcoding, you could install RaceChrono Pro to a second, higher end device. A tablet maybe?
