Hello.
I was wondering if it is possible to use a Raspberry Pi 3 to transmit data to RaceChrono Pro for iOS using bluetooth.
I want to make a DIY data logger using the Pi.
Is it possible to transmit live data via Bluetooth? Or maybe WiFi?
What protocol must be used? (I am quite new to this
Does $RS3 work with RaceChrono for iOS?
Can I use the phone connected to the Pi as a live dashboard for, let's say, my kart?
Are there any plans for the app to work with the QStarz BT-Q818 XT GPS receiver?
Thank you very much.
I'm also thinking about similar format for Bluetooth LE, which works fine on iOS. It would need to be a completely new binary format, as there's big throughput constraints on LE.
iOS does not support Bluetooth RFCOMM protocol, the basis of $RC3 and standard NMEA input devices, which is also the reason why there's no support for QStarz BT-Q818 XT.
Would you (or someone else) please tell me how to make it work over Wi-Fi?
Maybe just the basic steps.
Thanks,
That way it is more versatile, users being able to make their own DIY data logging system even for cars/karts that do not have OBD capabilities.
And the "Wi-Fi data logger" would be nice
Would it be too much to ask for a time frame for implementing this (IF you implement it)?
Thank you for taking the time to explain this.
I don't know if this is relevant.
Any approximate ETA on the implementation of all this?
