Arduino code ?
Hello, I have a data logger arduino, I'm looking for a piece of code to be able to send information to race chrono, can help me, I'm a beginner
  • edited February 2018
    Here is the code I am using. I am sure it can be improved a lot.
    And I still need to find a way to make the checksum show the ”0”.
    It calculates RPM, gear, accelerator position, brake position, and temperature. (for now)
    int rpm = 0, gear = 0, brake = 0, acceleration = 0, sensorValue1 = 0, sensorValue2 = 0;
    unsigned long count = 0, lastmillis = 0;
    volatile int half_revolutions = 0;
    unsigned long debounceDelay = 200; // the debounce time;
    unsigned long lastDebounceTime = 0; // the last time the gear was changed
    void setup(){
    Serial.begin(9600); // 9600
    attachInterrupt(0, rpm_fan, FALLING);
    pinMode(A0, INPUT); // acceleration
    pinMode(A1, INPUT); // brake
    pinMode(11, INPUT); // gears +
    pinMode(12, INPUT); // gears -
    void loop(){
    if (digitalRead(11) == HIGH){
    if ((millis() - lastDebounceTime) > debounceDelay) {
    gear += 1;
    if (gear>6){
    gear=6;
    lastDebounceTime = millis();
    if (digitalRead(12) == HIGH){
    gear -= 1;
    if (gear<1){
    gear=1;
    int reading = analogRead(2); // converting that reading to voltage, for 3.3v arduino use 3.3
    float voltage = reading * 5.0;
    voltage /= 1024.0;
    float temperatureC = (voltage - 0.5) * 100 ; //converting from 10 mv per degree wit 500 mV offsetto degrees ((voltage - 500mV) times 100)
    sensorValue1 = analogRead(A0);
    sensorValue2 = analogRead(A1);
    acceleration = map(sensorValue1, 0, 1023, 0, 100); //maps the input value of 0-1023 to 0-100
    brake = map(sensorValue2, 0, 1023, 0, 100); //maps the input value of 0-1023 to 0-100
    if (millis() - lastmillis >= 100){ //Uptade every one hundredth of a second.
    detachInterrupt(0);//Disable interrupt when calculating
    rpm = half_revolutions * 60; // Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use half_revolutions * 30.
    half_revolutions = 0; // Restart the RPM counter
    lastmillis = millis(); // Uptade lasmillis
    attachInterrupt(0, rpm_fan, FALLING); //enable interrupt
    String buffer = "RC2,," + String(count) + "," + rpm + "," + gear + "," + acceleration + "," + brake + "," + temperatureC + ",,,,,,";
    String checksum = String (checkSum(buffer), HEX);
    String data = "$" + buffer + "*" + checksum;
    Serial.println (data);
    if (count == 65535){
    count = 0;
    else
    count+=1;
    char checkSum(String chars) {
    char check = 0;
    for (int c = 0; c < chars.length(); c++) {
    check = char(check ^ chars.charAt(c));
    return check;
    void rpm_fan(){
    half_revolutions++;
  • Thank you, my data logger works, the only thing I miss is the receipt of data by race chrono, I think my syntax is not good for race chrono
