hi Guys, I am a RC pro android user and i have the below questions: - How does racechrono pro app extract g force data, is it from the phone or the external GPS? - if i have a value of 0,85 of Air Fuel ratio, what does that mean?
Unfortunately, I lost or delete the sessions on my tablet. I will need to record a est session to look at the log. Which file has the G force data? I will be testin on a straight "track" or road.
At the least, you could simply watch the video with G force overlay, and stop the video at the times you want to record the G-force.
It's hard. But you can re-import an NMEA file in RaceChrono for Android. First copy the file to /Android/data/com.racechrono(.app|.pro)/files/input/ . Then enable Settings > Expert settings > Experimental devices. Then add GPS device with type "NMEA input", and select the file you've just copied.
@DonC I don't understand what you mean. There's no other way to use an external GPS with RaceChrono on Android, than adding them in RaceChrono settings...
One of the GPS devices you can add is called Dual XGPS 150/160. Maybe it just refers to either, with no difference in the positioning data, even though the 160 GPS has more capability than the 150, like the 10 Hz updates.
@DonC, yeah you should use the "Dual XGPS 150/160" option when you configure your Dual XGPS 150 with RaceChrono. In Android, only difference to "Bluetooth GPS receiver" option is the update rate configuration for 150. On iOS there's other differences too. It can detect between 150/160 so each device is configured accordingly.
- This is equivalence ratio: https://en.wikipedia.org/wiki/Air–fuel_ratio#Air–fuel_equivalence_ratio_(%CE%BB) . There is also a channel for the "normal" gasoline Air/Fuel ration in graphs which is around 14.7.
Can i say the position and placement of the phone does not affect Long/Lat values?
If you already use the Dual 150 GPS device, why would you add the "Dual XGPS 150/160" as a GPS receiver? Does it add any extra features?
