lean angle - iphone
how exact is the lean angle messured with an iphone. on straits its more or less exactly on 0 degree.
my maximum degree yesterday was at 62,8 degree. this is fucking a lot. yes, i have problems with space to the ground and its hazing a lot ... but 62,8??
is there any way to control it with referenz data .... any ideas?
  • It's calculated from GPS data, which means it's theoretical. While it's correct (in theory) with GOOD GPS data, it can be wrong with bad GPS data, such as when using the internal GPS.
  • i use a GNS2000 so it should be good data. how is this calculated? a relation of position on the track and speed?
