This is not working for me; Same versions (RaceChrono Pro V6.0.11, Dashware 1.9.1) - I exported as "RaceChrono v2.20+ (rcz)", but DashWare won't interpret it (I selected RaceChrono V2 in the DashWare data profile dropdown).
It throws:
Data Logger File Error
Error using data profile 'RaceChrono V2' to read data logger file 'session.rcz' Error locating required column(s): You must map a dta column to the " \Data Running Time, Seconds" data type.
I also tried CSV, but I could not find a DashWare profile that would interpret this. This used to work fine, about 2 years ago...
Assistance appreciated! I can send screenshots, but I can't see a way to paste them here....
@aol I tried CSV too, as mentioned; Dashware does not have a "CSV" input format; I can't paste screenshots here - can you send me an email address via DM please...
Select "DashWare/..." from RaceChrono export type (which will produce a .csv file), and then "RaceChrono" from Dashware. Just tested this couple of weeks ago, with no problem.
Thank you!
It throws:
Thanks!
