Hello everyone, I have seen in the app that the P600 is supported, but I would like to know if the P610 is also supported.
Also if anyone tested that gps module
Thanks!
Fede
Ok thanks, also I have another question regarding any BT Gps, I already use a OBD2 BT module, it is possible to use both at the same time via Bluetooth? Also if it is possible, will it affect the update frecuency?
Thanks!
So right now I do not have plans to support P610. Buy P600 or some other device instead.
I’m on the market for a GPS receiver and now most of supported ones seem to be out of production.
https://racechrono.com/article/faq/which-external-gps-should-i-buy
PGear P610 is not officially supported as the manufacturer did not want us to support it. It may (or may not) work with the P600 setting, but only as 10 Hz, as it being a true 20 Hz device is a lie. It's a 10 Hz GPS with some software tricks.
So if you prefer RaceChrono over PGear's own app; don't buy PGear.
If you like RaceChrono, please see https://racechrono.com/article/faq/which-external-gps-should-i-buy or wait for the upcoming RaceBox Mini https://www.racebox.pro/mini/. I will start creating support for that once I get one. And this manufacturer is 3rd party app friendly. Disclaimer: I don't have one yet, so I cannot say how good it is, but specs look very good
