VBO import with custom data columns
This discussion was created from comments split from: RaceChrono v7.5 beta.
  • Hello, are there any hints how to properly include custom channels in the VBO source ?
    - Added custom channels imported from .VBO files
    I try just to include 1 additional column with my own naming, but in the imported VBO session, i can still only see the GPS related channels. I'm a beta tester
  • @ankel
    You can name the columns (channels) using rc_ prefix on the channel identifiers defined here: https://racechrono.com/support/equations/identifiers . So use "rc_brake_pressure" for example. The data units need to be mostly in SI base units, such as km/h, meters, degrees etc.
  • Working like a charm. Thank you for the link to documentation
