Map view: Driving line color channel [speed delta]
edited September 2024 in RaceChrono for Android
The 'speed delta' choice for the 'driving line color channel' appears to be rendering incorrectly.
(A) Select any session and compare two laps. Change the 'driving line color channel' from whatever the default is (eg: 'speed') to 'speed delta'. If you zoom in very close in the map view, you can see one of the lap lines is colored a solid yellow for the entire lap, and the other is colored a solid red for the entire lap. Areas where the two lines overlap appear orange due to the line transparency. The coloring does not represent the speed delta.
(B) Leave the 'driving line color channel' as 'speed delta', and go back to the 'Sessions' screen. Select any session and compare two laps again. The driving line on the map now appears to be colored with the 'longitudinal acceleration' rather than the previously selected 'speed delta'.
RaceChrono (Pro upgrade) for Android v8.0.8
