Storage not mounted
Hey,
I am using the RaceChrono Pro on my old phone a Xiaomi Mi9T Pro using a custom ROM called EvolutionX, I'm not using the stock OS anymore as it don't get system updates anymore. Whenever I tried to open the app I was getting a "Storage not mounted" message and it was prompting me to cancel or retry.
I took a look on the logcat and I saw this line:
"ContextImpl: Failed to ensure /storage/emulated/0/Android/data/com.racechrono.pro/cache: android.os.ServiceSpecificException: (code -1)"
so I quickly drop into the adb shell and run the following to creating the directory:
"mkdir -p /storage/emulated/0/Android/data/com.racechrono.pro/cache" -> For the Pro
"mkdir -p /storage/emulated/0/Android/data/com.racechrono.app/cache" -> For the Free version
And after that everything was working fine, so I just wanted to leave this here, so if more people have the same problem could possibly find a fix for the problem
Thanks,
MiguelNdeCarvalho
  • Got a new phone, moving from Google Pixel 4 to Pixel 8 and face the same issue. Running default Android OS 16. The "Files" app does not let me create those folders. Anything else I could do?
  • Update: solved by doing a clean install of the new phone. Pro-tip: don't migrate your old phone to the new one.
  • @mart_nl Thank you for the new information on this bug. We'll try to fix it once again.
  • I'm having this same issue on Google Pixel 9 Pro XL. I did not migrate from my old pixel.
  • @sgtdan707 yep, will remove the check completely, as it was for old Android versions not supported anymore anyways. Hopefully there's not directory missing or something that will cause a crash. But at least then we can fix the crash.
