Time delta value in exported data file
Hi.
I am not very into the technical part of the thing therefore I would like to kindly ask you. I am using RaceChrono Pro + RaceBox Mini. The sessions are exported into the CSV V2/Racerender/dashware format. In Racerender I am able to visualize all the data I am interested in except for "live delta (time)". From what I understand, RaceChrono does not export this value or even does not record this vaule. I am right? Would it be possible to record and export the exact value which is visible on the phone display on the track?
Thank you very much for your help.
  • I think I found perfect solution- I am going to record phone screen with some screen record app and then I will add the area with delta into the video from GoPro 8-)
