Wintec WBT201 at more than 1Hz
Hi, racechrono works fine on my HTC Cruise2 (WM 6.1) with a Wintec WBT 201 GPS bluethoot unit. The standard frequency of this GPS unit is 1 Hz, but it can be "overclocked" up to 4 Hz. I've noticed that my racechrono works fine up to 2 Hz. Rising frequency over 2 Hz makes racechrono not working. At 3 or 4 Hz it seems like there are some communication problems between phone and GPS unit. At those frequencies the live Hz counter in live timer mode gives erratic data: the frequency it' unstable, it floats between 0.5 (approximatively) and 4 Hz. What could be causing this problem?
Thanks in advance and sorry fo my english.
Regards from Italy.
Riccardo
  • Try raising the baudrate from RaceChrono's GPS settings.
  • OK, thanks.
    Now baudrate is setted to "Default", what value do you suggest?
    Bye
  • edited May 2010
    I've tryed to change baudrate, nothing changes! :-(
    Both with 38400 and 19200 live Hz counter gives erratic values.
    It works fine up to 2,5 Hz.
    What can I do to solve this problem?
    Thanks.
    Riccardo
