RC 1.40 on Windows7 notebook - lockup
New user of RaceChrono and am just becoming familiar with the program.
At this time am only running on a PC (don't have a compatible Phone - Nokia 6234 but getting a 5230).
Program appears to work OK until time comes to close out.
Problem is absolutely repeatable whenever the 'Pause Session' dialog comes up and the program stops working - no messages but after a time the (Not Responding) message appears on the title bar.
Problem arises with or without GPS configured or connected - i.e. after initial installation and just working with sample file.
Can you advise what I may be doing incorrectly or what to look for/change in the PC setup.
Have saved the log files referred to in the description below compressed in .rar and can forward them to you if required.
PC Details:-
RaceChrono for Windows PC ver 1.40
PC is Compaq 6710b
Windows 7 Professional fully updated and patched
MS Office 2010 Professional Plus installed
Qstarz 818XT connected via USB cable.
Windows' Description of the problem:-
A problem caused this program to stop interacting with Windows.
Faulting Application Path: C:\Program Files\RaceChrono\RaceChrono\RaceChrono.exe
Problem signature
Problem Event Name: AppHangB1
Application Name: RaceChrono.exe
Application Version: 0.0.0.0
Application Timestamp: 4b800c7d
Hang Signature: ba82
Hang Type: 0
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 5129
Additional Hang Signature 1: ba821a02ca495fcb9c89d705b95518d1
Additional Hang Signature 2: 8ea8
Additional Hang Signature 3: 8ea8b27c4c452ba29461c6098268985d
Additional Hang Signature 4: ba82
Additional Hang Signature 5: ba821a02ca495fcb9c89d705b95518d1
Additional Hang Signature 6: 8ea8
Additional Hang Signature 7: 8ea8b27c4c452ba29461c6098268985d
Files that help describe the problem
AppCompat.txt
WERInternalMetadata.xml
RaceChrono.exe.xml
memory.hdmp
minidump.mdmp
  • Right click on racechrono.exe and select "run as administrator".
    This has stopped my racechrono from locking up after pausing a session.
    Paul
  • edited November 2010
    Thanks Relli10,
    Always run Windows in Administrator mode!
    Have been doing further testing and the problem has resolved itself.
    I think there was a problem with the Windows set up.
    This particular notebook does not appear to have Bluetooth built in as it seems it is an option variation. Had attempted to install 2 different HP Bluetooth drivers when changing from XP to Windows 7 but they would not install, however there was software left in control panel etc. Have now stripped those out and the problem has now gone. I do not know for sure if this was the answer or was a co-incidence.
