mounting a phone on steering wheel
Im in karting and I love Racechrono. I would like to use it for predictive timing and wanted to know if anyone has successfully mounted their phone on a steering wheel.
  • edited August 2014
    I would use a suction cup mount if the steering wheel has enough flat space on it (iOttie has a good suction mount we like around here). Otherwise, you may have better luck with a "tube clamp" style mount, similar to the go-pro roll bar mount (in that case I would probably mount it on a bar behind the steering wheel.
  • thanks for the info. unfortunately there is not enough space for a suction cup, and no tube behind the steering wheel to acommodate it.
    Im thinking of making something out of a strip of plastic.
    thanks for the response.
    any and all responses welcome.
  • edited September 2014
    I setup a Samsung Galaxy S3 on a TonyKart steering wheel.
    To do it, I used a Defender series OTTEROX :
    http://www.otterbox.com/defender-series/defender-series,default,pg.html
    I modified the Holster to feet onto the lower side of the steering wheel (Alfano is on the upper side).
    => AOL: How to publish a photo into a message ?
    Regards
    Saturne06
  • Just inline HTML img tag to post images.
