2.1K
1K
Update Rate on IOS | External GPS | Garmin GLO 2
UriasBarbosa
November 2019
Does someone know if I buy the Garmin GLO I will get the 10Hz update rate? Which is the best external GPS for IOS?
aol_of_RaceChrono
November 2019
edited November 2019
No, you will only get 3-4 Hz on iOS unfortunately. On Android it would be 7-8 Hz.
Here's the recommendations from the FAQ:
https://racechrono.com/article/faq/which-external-gps-should-i-buy
Not yet added to list, P-Gear P600 is also very good and affordable. I will also work on the P610 support soon.
UriasBarbosa
November 2019
thank you for your answer. The P610 gets a better update rate than this others for IOS?
aol_of_RaceChrono
November 2019
P-Gear P610 is not yet supported, but I believe it will be near or full 20 Hz. The P600 runs at 10 Hz reliably.
Here's the recommendations from the FAQ: https://racechrono.com/article/faq/which-external-gps-should-i-buy
