Hello, im relativ new here and im sorry if I did not see the solution to my problem here in the forum already.
I have the problem, that when I connect my second GoPro to RaceChrono it says I have to deactivate my other GoPro, because of some Configuration Conflict.
How do I fix this problem? Or is it not possible to control both GoPro's at the same time with Racechrono.
Do I need to manually start the second GoPro and sync the files afterwards?
RaceChrono also has Bluetooth connectivity to the GoPro's but it's little bit experimental feature, so haven't put the effort to connect to two simultaneously... Also the preview picture would not work through Bluetooth only.
You can manually turn the recording on/off on the second camera (or why not both). RaceChrono has automatic sync feature if you have the GoPro's GPS turned on: https://racechrono.com/article/480 . Usually this automatic sync works much better than the sync that is done by the remote control feature.
I now connected both cameras normally, but only one was active. The other one, I started manually nearly at the exact time as the one connect to RaceChrono. At the end I did the same. After my session I can transfer files from the first GoPro and the second one, because both are linked to the App. I only need to sync the second one and that's it.
