It only supports the ones that are on selectable by Brand/Type. UUID alone is not enough as each of them implements proprietary binary protocol.
If you're building your own GPS, you can follow this protocol description https://github.com/aollin/racechrono-ble-diy-device . There's also working Arduino code which you can modify to your needs. This device is added from "RaceChrono > Settings > + Add other device > RaceChrono DIY > BLE > GPS".
