I'm considering upgrading my logging setup from my current qstarz bluetooth GPS to a Racecapture Track MK3. This will allow me to read steering angle and brake pressure from my car's CANbus, as well as increasing GPS update rate from 10 to 50Hz. Ideally though I would like to keep using RaceChrono; does RaceChrono currently, or are there any plans to, support connecting to a RaceCapture?
I doubt it would attract enough new users to RaceChrono to recoup the development and testing costs of the full "live connection" support unfortunately. Also the manufacturer (AutosportLabs) wasn't exactly keen on adding the support in RaceChrono, when we talked briefly few years ago, so I wouldn't be getting any support from there either...
It may be worth checking if you can download your data in some nice format from RaceCapture, so then it could be supported through data import.
FWIW I'd also be happy to shell out a bit more for that support. RaceChrono Pro+?
If I were to buy the unit and lend it to you for initial development testing, would that help? Or would you need one you could keep in order to support it? As I understand it, the device has an open data format and API, although I haven't seen any details on that.
