gnss imu fusion
I found a library about improving GPS stability
Can it be added to racechrono to improve track record quality?
Or maybe something like the u-blox Dead reckoning series like the Neo-M9V
Improved position report update rate through sensor fusion, from 5hz to 50hz
In this way, can racechrono achieve 10hz or higher update rate using the phone's built-in GPS and sensor fusion?
This is the library link
https://gps.maddevs.io/en
https://maddevs.io/blog/reduce-gps-data-error-on-android-with-kalman-filter-and-accelerometer/
https://github.com/maddevsio/mad-location-manager
  • Interesting, thank you for the tip. I will take a look at it.
