I'm having some issues syncing my data to video on the 1.10 files I have. I though I read a feature on 1.3 that makes this easier???...but can't find it now.
is it possible for the blutooth obdkey to have a delay from the 5ghz gps data from 818?...so the throttle and tach do not match eachother...different obdkey channels and they don't match the speedometer..."I think" form the gps?
Is it possible to correct this with a post process?...or maybe I could use the Obdkey's speed whhich should match better?...but I believe the Obdkey's speed is not as accurate as the gps???
Could this error be because the Obdkey does not putt a 5hz stream???...or delay in the bluetooth???
tia,
mr
The reason it happens is simply because RC has to request the data from OBDKey, which then has to request it from the ECU over a pretty slow interface. This takes time. The GPS constantly throws data at RC as it calculates it, which scribbles it onto your memory card as it comes in. This is much quicker.
