Fail to export video on bluestacks/windows
I wanted to work on my track video from my PC.
Everything work fine until last step when I launch the video export. (if I try the exact same export from my phone it works)
Does anyone had this issue ?
Is there a way on racechrono to know why the export failed ? (Only the video export seems to fail, tried quality and hardware accelaration, no diif)
  • I tried again with the "save debug logs" option.
    Any idea what the issue is ?
    3 nov. 2022 12:47:36 PM Input video format: {mime=video/hevc, frame-rate=50, rotation=0, rotation-degrees=0, track-id=1, profile=1, width=2704, height=1520, max-input-size=576511, durationUs=708000000, csd-0=java.nio.HeapByteBuffer[pos=0 lim=93 cap=93], level=65536}
    3 nov. 2022 12:47:36 PM Bitrate: frame height = 1520
    3 nov. 2022 12:47:36 PM Bitrate: retry = 0
    3 nov. 2022 12:47:36 PM Bitrate: quality = 3
    3 nov. 2022 12:47:36 PM Bitrate: quality multiplier = 2.0
    3 nov. 2022 12:47:36 PM Bitrate: hw max = 3000000
    3 nov. 2022 12:47:36 PM Bitrate: retry multiplier = 1.0
    3 nov. 2022 12:47:36 PM Bitrate: guesstimated max = 40000000
    3 nov. 2022 12:47:36 PM Bitrate: brute force bitrate = 40000000
    3 nov. 2022 12:47:36 PM Bitrate: using bitrate = 40000000
    3 nov. 2022 12:47:36 PM Output video format: {width=2704, height=1520, bitrate=40000000, mime=video/avc, frame-rate=50, i-frame-interval=10, color-format=2130708361}
    3 nov. 2022 12:47:36 PM Input audio format: {mime=audio/mp4a-latm, aac-profile=2, channel-count=2, track-id=2, bitrate=48000, max-input-size=605, durationUs=707989333, csd-0=java.nio.HeapByteBuffer[pos=0 lim=5 cap=5], sample-rate=48000, max-bitrate=48000}
    3 nov. 2022 12:47:36 PM Output audio format: {pcm-encoding=2, aac-profile=2, mime=audio/mp4a-latm, channel-count=2, bitrate=192000, max-input-size=0, sample-rate=48000}
    3 nov. 2022 12:47:36 PM Input format: {mime=video/hevc, frame-rate=50, rotation=0, rotation-degrees=0, track-id=1, profile=1, width=2704, height=1520, max-input-size=576511, durationUs=708000000, csd-0=java.nio.HeapByteBuffer[pos=0 lim=93 cap=93], level=65536}
    3 nov. 2022 12:47:36 PM Input format: {mime=audio/mp4a-latm, aac-profile=2, channel-count=2, track-id=2, bitrate=48000, max-input-size=605, durationUs=707989333, csd-0=java.nio.HeapByteBuffer[pos=0 lim=5 cap=5], sample-rate=48000, max-bitrate=48000}
    3 nov. 2022 12:47:36 PM General failure
    3 nov. 2022 12:47:36 PM java.lang.IllegalStateException
    at android.media.MediaCodec.native_dequeueOutputBuffer(Native Method)
    at android.media.MediaCodec.dequeueOutputBuffer(MediaCodec.java:2570)
    at o.DefaultAnalyticsCollector$$ExternalSyntheticLambda44.write(:236)
    at o.DefaultAnalyticsCollector$$ExternalSyntheticLambda45.read(:23287)
    at o.createExtractors.AudioAttributesCompatParcelizer(:256)
    at o.format.run(:110)
    3 nov. 2022 12:47:36 PM Closing failure
    at android.media.MediaCodec.native_stop(Native Method)
    at android.media.MediaCodec.stop(MediaCodec.java:2007)
    at o.DefaultAnalyticsCollector$$ExternalSyntheticLambda44.Mp4Extractor$Flags(:279)
    at o.DefaultAnalyticsCollector$$ExternalSyntheticLambda43.getTrackIndexOfNextReadSample(:236)
    at o.DefaultAnalyticsCollector$$ExternalSyntheticLambda45.read(:205)
  • Maybe try lower resolution? I'm not expert on BlueStacks at all, and I don't know what kind of hardware it emulates, but 2.7K resolution is quite high.
