I send $RC3 at 10 Hz update rate via WiFi -- the rate is consistent (and reported by RaceChrono) as long as I leave RaceBox disabled.
Problem: When I enable RaceBox (BLE), then I get a low and inconsistent update rate of $RC3.
HW and SW: Oscal S80 Android phone with RaceChrono Pro v8.0.8.
The problem is not present when testing it on a Samsung Galaxy (which I prefer not to use while racing).
Is there a setting or something I should try in order to make this work better?
e.g. $RC2 messages instead of $RC3, or a different update rate....
When I enable both RaceBox and $RC3 WiFi in RaceChorono, then RaceChrono reports an inconsistent $RC3 update rate, and data is missing (or misplaced?) also in the log.
What can be causing the problems?
I will try to use another app to connect to the RaceBox (instead of RaceChrono) -- to check if that one also blocks/buffers the WiFi ($RC3 messages).
BTW: very little support there -- no reply for more than a month.
