Hey Folks
Can you please add a way to export multiple sessions in bulk. This would make things considerably less painful
As an example, I have recently gone on a wild goose chase trying to figure out why RaceChrono Pro was so inaccurate compared to integrated lap timer, only to realise that the official Queensland Raceway finish-line published on the app has the finish line no where near the real one. Unable to submit the change online or notify of this error, I had to download the map and change it myself, save the map as 'My Track'
Then, I had to go and change every session to this new map, and re-export everything. Which took ages and was more difficult than it really should be
If you have time, I highly recommend you go through trying to export a few sessions and see how much back and forth there is. Rehaul of this 'forward, forward, forward, back, back, back, back' process via a better UI.
The feature set of your app is unparalleled however the interface, menu structure and convoluted methods to achieve simple processes is stuck between 1990-2009 and this is where the app is most lacking
For the record I will continue using RaceChrono Pro and love what you have done. Just wish you could streamline things a little more
As a suggestion to achieve just the bulk export. In the sessions menu, long hold on a session, which brings up radio boxes on the left hand side of all sessions. User ticks boxes and taps three dots top right column to export in bulk
Thank you
