RaceChrono has an "Arc" gauge for video overlays; a circular bar graph renders from a minimum to maximum value.
The suggestion would be to provide an option to change the way it renders negative numbers.
Given a hypothetical example gauge from min -50 to max +100, here are some ASCII representations. Please imagine a fixed-space font (or copy-paste it into a fixed-space font editor/terminal):
Existing implementation:
-50
-25 #
0 ##
+50 ####
+100 ######
Alternative implementation
-50 %%
-25 %
0
+50 ##
+100 ####
Ideally, the negative numbers would have a different "Indicator Color" from the positive numbers (as shown in the above % versus #).
As described, I believe the alternate implementation would look the same as the current implementation for non-negative numbers. However, I presume that it is strongly desirable to default to existing negative number behavior for users that want to keep the existing approach.
Thank you for the consideration.
