I'm setting up Racechrono for can bus telemetry but the obd2 port of my car does not expose the can bus and the can wires are on the passenger's side.
My idea is to connect hte MX+ with only 4 wires on the passenger's side (power, ground, can H and can L), skipping the obd2 port altogether.
Obdlink support says it can be possibile, although their app won't work, but advised to confirm with Racechrono.
Looking for advice here.
Best,
Max
I have the MX+ setup like this on my 911. I’m not currently using RaceChrono but the other software I use it works great. I’ll try RaceChrono today and see how it works with this style of setup.
Yes, works just fine.
Detailed photos in this link showing all the hookups all the way to RaceChrono.
https://www.718forum.com/threads/successfully-hacked-my-718-gts-can-bus-for-racechrono-data.31918
CAN Crocodile requires you to have two powered devices - the OBDLink and the Crocodile. Much simpler to just tap the cable directly.
