Custom Track Trap Coordinate Editing
When creating custom tracks, the UI only allows us to locate the traps by panning the map. This works well if you're starting from scratch, and you can see the track on Google image or are recording a track on-site as a passenger. However, if you're working with existing GPS records, or transferring track configs from other lap timing/mapping apps, and you want the traps to align perfectly, you have to zoom all the way in, then move the map around until the lat/long numbers are both correct. It would be more convenient if we could simply tap on the coordinates and type in the numbers. This applies to trap rotation as well, as users with small screens may find it difficult to reach a specific number using the slider.
