Disable Position Synchronizing When Comparing 2 Laps Possible?
I know that when comparing two different laps, there is some synchronizing going on so that (I believe) the positions start/end in the same spot, but would it be possible to disable this? I know there is the time delta channel which will show you where you're making/losing time, but I think it would be easier to see it VISUALLY on the track.
For example, maybe entering a corner a little wider sets you up better for the exit. Currently, I find it hard to QUICKLY tell if I'm just carrying more speed that yielded a better time, or if I took a better line (wider corner entry) that yielded a better time. I think if I could see my positions de-syncronized from each other when comparing runs it would make it easier to see how the different racing lines perform.
  • I think you are talking about stuff you can modify under graph settings. Click on the graphs at the bottom, then on the cog. Scroll to the bottom and select something else for Comparison X-axis scaling.
