Microsoft PocketPC / WindowsMobile Bluetooth Card Socket
Hello all,
I currently try to get RaceChrono working on my PDA (Acer N10 Windows Mobile 2003 Version 4.20.1081 (Build 13100)) together with the bluetooth Card socket (8510-00159G) and an Iblue 5 HZ GPS. So far, if I use a tool like GPSViewer I can see the receiving data, e.g. CoM 8 Baud 115000.
In RaceChrono 1.4 I tried using gps settings GPS receiver and Serial Gps with the same details I use in GPSViewer but unfortunately if I try to start a session it always ask to activate the bluetooth Device, it doesn't matter to say yes or no, the result is always "Error in turning on Bluetooth. Notice if your device ... WIDCOMM... ". As far as I know I'm not using a WIDCOMM BT Stack, but not totally sure.
Please could someone assist?
  • edited August 2010
    Try configuring RaceChrono to use same COM port (instead of using Bluetooth directly) as the other software. Should work just fine.
