a few questions about the latest version 2.44 of raceChrono:
I see the various track maps have two sectors that are built in, how do I add more sectors?
is there a analysis mode off hi and low speeds for sector?
I see a ghost location: following the individual lap while being analyzed,is the ghost indicator the best lap of the same session for the optimal lap?
last, I'm using this in conjunction with racerender.I'm trying to pull in throttle and coolant temp from the obd reader but it doesn't seem to be displaying on race render. Have those functions become active?
BTw the setup I'm using which includes a 818 XT and Samsung smartphone running 4.1 Androidthat worked perfectly at the vir race track -----great work.
The ghost lap is the current comparison lap, which is the best lap by default. You can change the comparison lap from the toolbar.
Can you see the coolant temp and throttle channels in the exported CSV? If you can see it, it's up to the RaceRender (and the user
I just did the splits and everything worked out fine very slick approach to managing that.
regarding throttle and coolant temp I did see it on my handset display but when I opened up the CVS or CSV file I did not see
any data for coolant temp or throttle.if its showing up on my handset shouldn't be in the data file?
I've gotten all the data working with the approptiate videos and everything seems working properly, great job.
I have to say all the editing and exporting is very easy
to do.
Going foward, any plans to include oil pressure/temp
Data?Those are two fields that are very important at the
track.
Again- great work on this product.
I see the oil temps selection but do not see anything on oil pressure; is it there and I'm just not seeing it?
Also, the selection of throttle position indicator--absolute vs. relative--?? what is the difference between these choices (there are several)?
thanks
The trottle position question is interesting one that I do not know full answer to. Some of the channels measure the throttle body position, and some accelerator pedal position. But what is different between relative and absolute... dunno.
I know for a fact that on Audi TT mk1 the "Throttle position" and on BMW e90 LCM "Accelerator pedal position D" outputs accurate the gas pedal position. What it is on your car, you'll have to find out.
There probably has been something mentioned about charting your braking effort but I can't find it.
I see where my braking effort is on the track map but wonder if there is a way of getting numeric figure or chart of brake application for a particular turn?
thanks for any help.
