There is actually a GPX export, just change the type to GPX from the export dialog. There is a problem with the "Traveled route" scope in v1.00, as there are some extra tags generated, but this is fixed in v1.02 beta.
Or do you have problems in using the exported file?
That's what I'm using, but resulting GPX is of version 1.0, while the latest one is 1.1. I tried to install both betas on my n73 (from over here http://www.racechrono.com/news/?p=59&lang=en), but neither of those could be installed on it.
To use the betas you need to join the beta group. There is a news post about it. Is there much difference between 1.0 and 1.1? What is the software you need to have it working on?
All right. When I have time, I will take a look at that and see what is needed. Did you try to edit the file by hand, eg. version number from 1.0 to 1.1? There should not be much difference between 1.1 and 1.0.
Cheers
Is there any other way around it?
Cheers!
Thanks for your replies
