Problem with Video Overlay Export
I try to export an 3,5 GB .mp4 video with overlay of speed, acc and map on an external SD with 35 GB or internal with 8 GB free space but it doesn't export with error "not enough space". What am I doing wrong?
  • Did you select external storage before pressing start button on the export queue? The exported video might be a lot bigger than the source (depends on the quality setting). Might be 8 GB is not enough. 35 GB should be.
  • Problem solved. The video codec didn't work for exporting (no problems with viewing)...With a well converted video everything works fine.
  • edited April 2015
    Great to hear you got it sorted. Which video source and codec did you use for the raw video? Can you provide me example of the "non-working" video file (dropbox or google drive url)? I'd like to fix the error message that is obviously wrong...
