Hi, I use ODB-II Bluetooth device to send car data to phone.
RPM and Throttle position get recorded, show on the analysis and i can export that data on the CSV file, but the oil temp and coolant do not.
I have the oil and coolant check marked on the fast channels.
Any idea why not? how can i fix that?
thanks,
Ofer
1) Press the green/red button from bottom left of the recording screen. Device status panel appear with gauges for everything that is being recorded. Can you see oil and/or coolant temperature?
2) Click 'Fast channels' button. Are those channels available on the list? If not your vehicle does not support these channels.
Coolant temp channel is supported by most vehicles (but not all), but the Oil temp channel is quite new and still rarely supported.
-Antti
