Just bought Pro so I can record and export videos and export is not working.
Tried different settings (like internal/external storage)
Log file:
Aug 21, 2016 7:15:26 PM Input video format: {csd-1=java.nio.ByteArrayBuffer[position=0,limit=9,capacity=9], mime=video/avc, frame-rate=30, rotation=0, rotation-degrees=0, height=1080, width=1920, max-input-size=1572864, isDMCMMExtractor=1, durationUs=54447544, csd-0=java.nio.ByteArrayBuffer[position=0,limit=20,capacity=20]}
Aug 21, 2016 7:15:26 PM Bitrate: frame height = 1080
Aug 21, 2016 7:15:26 PM Bitrate: retry = 0
Aug 21, 2016 7:15:26 PM Bitrate: quality = 2
Aug 21, 2016 7:15:26 PM Bitrate: quality multiplier = 1.0
Aug 21, 2016 7:15:26 PM Bitrate: hw max = 17000000
Aug 21, 2016 7:15:26 PM Bitrate: retry multiplier = 1.0
Aug 21, 2016 7:15:26 PM Bitrate: guesstimated max = 40000000
Aug 21, 2016 7:15:26 PM Bitrate: brute force bitrate = 15000000
Aug 21, 2016 7:15:26 PM Bitrate: using bitrate = 15000000
Aug 21, 2016 7:15:26 PM Output video format: {height=1080, width=1920, bitrate=15000000, mime=video/avc, frame-rate=30, i-frame-interval=10, color-format=2130708361}
Aug 21, 2016 7:15:26 PM Output audio format: {aac-profile=2, mime=audio/mp4a-latm, channel-count=2, max-input-size=1572864, isDMCMMExtractor=1, durationUs=54316354, csd-0=java.nio.ByteArrayBuffer[position=0,limit=2,capacity=2], sample-rate=48000}
Aug 21, 2016 7:15:26 PM Output audio format: {aac-profile=2, bitrate=128000, mime=audio/mp4a-latm, channel-count=2, sample-rate=48000}
Aug 21, 2016 7:15:26 PM General failure
Aug 21, 2016 7:15:26 PM android.media.MediaCodec$CodecException: Error 0x80001001
at android.media.MediaCodec.native_configure(Native Method)
at android.media.MediaCodec.configure(MediaCodec.java:577)
at o.gm.(:44)
at o.gl.ˊ(:3097)
at o.gr.ˊ(:117)
at o.amo.ˊ(:255)
at o.ana.run(:90)
1) Which OS version?
2) Meanwhile not fixed, export using the "Hardware acceleration" option unchecked. It's a lot slower but should work. Looks like there's problem with initialising hw codec.
3) Email me at tracks(at)racechrono.com, I might have a test version with experimental fix for you.
