ObdLink MX wifi connection (hotspot)
Hi, i set my Obdlink MX to connect to my phone through a wifi hotspot so as to keep data connection, but racechrono could not connect to it. Is there a way to do it? i have no issues with its proprietary app and also with torque pro, i just had to give its ip address.
  • The device type "OBDLink MX Wi-Fi" uses fixed IP-address and TCP port 35000. If you want to have different IP address, use the "Wi-Fi OBD-II reader" instead, and define your custom IP-address and port 35000.
  • Thanks aol, this friggin' fast support!
    Even if I have just realized I left this post "unposted" for over a month! (solved with your reply right after you wrote)
