Hi aol,
Before reporting the bug, I appreciate you to add 'combined acceleration' feature on Racechrono!
Today I found 'custom storage settings' doesn't work properly in Android version 7.x, the setting in Android 5.0.1 (galaxy s4) works fine though.
In 7.x, when I set the custom folder as external SD's movie paht (~~/DCIM/Movie), it doesn't show 'Custom storage' in the video link menu, but it only shows 'External storage' which is default path in external SD (~~/com.racechrono.pro/files/movies/racechrono).
Weird thing is that if I set the custom folder as external storage path (~~/com.racechrono.pro/files/movies/racechrono), it shows Custom folder and External storage both.
Would you please check what the problem is?
Thank you.
1) galaxy S4 lte-a : works fine
2) galaxy Note8 : doesn't work
3) galaxy tap s3 : doesn't work (I wish it works in this device ^------^)
4) lg gpad 8.3 : doesn't work, tested on other OS ver, like 7.x, 6.x, but all of them doesn't work
5) Dell 5175 with remix OS(7.x) : doesn't work
I wonder there will be a fix for the issue above.
I realized that the fastest way to use video files is like..
1) recording a session and videos with auto sync function between Gopro and Racechrono
2) after recording a session, connect to Gopro for receiving the name of video files
3) move the sdcard from Gopro to the android device, Racechrono automatically play video files which sync is already matched.
(I know there's wifi-download function, but it takes long time)
4) now I can analysis my sessions with videos like plug-and-play!
But there's a big problem. Racechrono doesn't detact raw video folder but external storage in some environments : galaxy S5 / galaxy Note8 / galaxy Tap S3 ...etc (OS is higher than 6.X)
Could you please fix this issue for real Plug&Play function?
https://photos.app.goo.gl/cX8TMFNoSYwWwug87
https://photos.app.goo.gl/ydzQoSZ5tyuvpaK27
Instead there will be a file picker in the import feature, that will allow users to copy video files from external drives to RaceChrono's raw video folder.
This allows you to do following (notice this is for upcoming v6.1 only, not the current versions):
1) Connect GoPro with USB-C to USB-C cable to your phone
2) Open RaceChrono's import screen
3) Select 'File brower'
4) Select the video file under GoPro
5) Wait until the file has been processed
6) Select data type 'Raw videos files only'
7) Press 'Start'.
8) RaceChrono will import the files from the GoPro to RaceChrono's raw video folder
9) You can now use the video files for your sessions
but I hope "Custom storage" expert setting remains at the next version of Racechrono, for Android devices which have lower OS vers.
Unfortunately these paths are no longer accessable in new Androids. Not worth adding just for some older Androids.
