How do I edit what overlaid data is shown?
Right now, my video is showing a G-meter, KPH, and RPM. I would like to change the KPH to MPH. My OBD-II reader is connected and in the settings it shows that it's tracking RPM, throttle position, intake temp., and coolant temp.
Thanks!
  • KPH => MPH you can change from settings: Speed and distance units: English
    You can add / remove gauges from "Edit overlay" option in analysis screen's video controls.
  • My display has 3 Overlays that you can select. Is there supposed to be a diffrence? They all look the same (timing on Top, Speed and Gs on bottom.)
  • They are the same until they are changed. Then you can choose from 3 configurations.
  • Is there a way to move a single gauge to a different place? If I move one, the whole group in that side moves with it. I noticed how the Up & Down buttons change the order, but not the position on the screen.
  • @DonC new overlay editor coming in v8.0 with more freedom
  • Great! I'll look forward to it.
