So I am aware of PIDs for this car, specifically these ones:
steering angle: 0x00D0
brake pressure: 0x00D1
However trying to create a custom PID using these values, RaceChrono says that these are invalid as it's looking for a two byte value, not a single byte.
Anybody have any idea how I can use these two PIDs? Know if I put in 0x01D0 then it'll accept it but obviously it's not the right PID for the data i'm wanting to track.
0x00 is really weird range. Have you tested these on Torque app or similar? Just checking that I won't do this work based on wrong information.
PID 0x00 normally gives you a List of the next 32 PID´s, which were supported. Like 1101... which means, PID 1,2 & 4 are supported.
Two bytes PID´s are also never seen by me on any ride/drive.
But there are things like reading failures, where you have a leading zero for selecting a specific error register. Or setting testmodes like (de-)activating a fan with 00 and 01.
Some Background:
0x just is a prefix to make sure that this were hex values!
00 D0 might only have leading zeros, which were placeholders for int / int16 (two bytes).
So probably this is only a developing paradigm. Where do you got the information from, to use 0x00D0?
0xD0 = 208
0x00D0 = 208
And for the nerdy ones: 208 = 11010000
Just give it a try with D0?
Currently RaceChrono does not allow 0x00 service ID at all, due to way the PID field is stored. I will change that if it's confirmed that this service ID is needed.
The only 0x00 I saw was as PID or to filter DTC (diagnostic trouble codes).
It might be 0x0021 & 0x00D0 just as a different notation.
Until we don´t know where tanner got his infos from, we can only guess.
https://forum.autosportlabs.com/viewtopic.php?t=5319
Unfortunately, these only provide pressed (255) / released (0) values, i.e. no intermediate values. Better than nothing?
To add a custom PID go to Settings, click on your FRS/BRZ/86 in the list of "Vehicle profiles".
At the bottom, click "Add channel".
In the "Channel editor", choose the right name for the channel, then click "Show more...".
Type 0x7E0 as "OBD-II header", tap the checkmark on the right.
PID: 0x221233 for brake pressed/released sensor
PID: 0x22122F for clutch pressed/released sensor
Don't forget to tap the checkmark on the right.
Equation: "B / 2.55", then tap checkmark on the right.
Don't forget to "Save"!
While at it, I also noticed that the "Relative accelerator position" was reporting 40...41% for me when flooring the pedal, causing RaceChrono to show 97% of throttle in my onboards. Knowing that 100/255 = ~0.39, I figured that can't be a coincidence. I looked at the "live data" and realized that "floor it" gives me something like 0x67 ... 0x6D, which corresponds to 103...109. Perhaps the values above 100 are just clamped to 100 in the ECU, and are there due to imprecision in the pedal calibration?
Anyhow, I ended up entering a "custom" PID for the accelerator pedal:
OBD-II header: blank (default)
PID: 0x015A
Equation: min(A, 100)
I FOUND IT!
Channel: Brake Position (%)
OBD-II header: 0x7B0
PID: 0x2141
Equation: min(100, 1.1 * max(A-10, 0))
Explanation: the min/max trick makes sure the output is in the [0%, 100%] range. The 1.1x is a multiplier that roughly matches the scale factor I previously chose for my CAN bus reader so that 100% is reported when I'm braking really hard. The -10 offset is to compensate for the default value of 10 (I've no idea why the reported value never goes below 10).
Enjoy!
Having said that, OBD-II provides a much lower refresh rate than CAN, so I still recommend investing a little time into making a DIY CAN reader as documented on my GitHub:
https://github.com/timurrrr/RaceChronoDiyBleDevice
