I'm using an OBDLink LX on RaceChrono Pro 7.1 (Android) as raw CAN-bus reader.
The app can read some ID such as 0x201 (rpm, accelerator pedal position, car speed) but not IDs 0x81 (steering) and 0x85 (brake)
For 0x81 it seems to read the first value and then get stuck at 00 00 00 00
Is this something to be fixed to RC side or a limitation on OBDLink side?
I know those IDs are available on the port because I logged them with a PiCan2.
@aol
I used the ATMA command with Serial Terminal Bluetooth for Android (I'm attaching both "text" format and "HEX" format) and then I went out and exported the device_output. It is not really clear to me how to interpret the results, except that I see in the device_output a lot of "data error" associated to a bunch of IDs including the 0x81 and 0x85 that I need.
PS: sorry for the double quote, something went wrong editing the post from android
@aol
Done, thanks!
Anyway, I think I've found the problem, see https://racechrono.com/forum/discussion/1854/can-bus-data-logging-was-custom-obd-ii-channnels-for-miata-nd2#Comment_11392
Would be happy to test the fix with OBDLink MX+ on my Subaru BRZ as soon as the beta is available.
