I'd like to use RaceChrone with the OBDlink MX+ in my McLaren 720S.
I got some documentation on the McLaren specific CAN bus PIDs (they all seem to use the same Bosch ECU) here:
https://www.mclarenlife.com/threads/can-bus-pids-for-720s.103985/post-1782393But McLaren seems to use pin 1+9 on the OBD plug for the powertrain CAN bus:
https://www.aimsports.com/download/ecu/stock/mclaren/McLaren650S_2014_100_eng.pdfDoes anyone know if the OBDlink MX+ can properly read that?
"While GM-LAN would be located on these pins(which MX+ has access to), this does not sound like an OBD-II network and it is likely you would need to verify that RaceChrono supports reading requests from this network)."
GM-LAN is pretty similar to CAN-Bus so I don't know actually if it would or would not work without the adapter cable. I bet there's a diagnostic CAN-Bus in the standard pins and the adapter will just access that bus....
